X type 2.5 AWD - 2005 - Engine coolant leak
iJaguar
I've recently bought a Jag X 2.5 SE AWD. It's been running good, however i have couple of things to clarify:
1) Drifting (This is the first time i am experiencing the AWD, so i am not sure whether the drifting is common)
2) Engine coolant is draining a lot.
3) Braking :- It takes lot of efforts to apply the brake especially on high speeds as compared to the FWD or RWD. Is it common in AWD?
Appreciate your thoughts.
--iJag
HI
Did'nt think the s-type had enough power to drift, only kidding
do you mean the car wanders a bit, could be bushes or something like track rod ends, if you jack it up, you should be able to feel some play in the wheels
engine coolant leak, have a good look, you should be able follow the staining and find it, usually a hose, radiator or something like coolant expansion tank, they fail
brake are usually very good, if there poor, could be seized calipers, faulty servo or split vacuum pipe to the servo,
