Parking sensor fault
Padster72
Hi all,
57 plate 2.2 Estate. The parking sensors are not working. I get a three second beep followed by the light on the roof flashing. I've checked the reverse lamps, both of which are working. I've listened to the front and rear sensors, and all eight of them click.
Does anyone have any experience of this? What is the fault likely to be? Is there a separate sensor module somewhere, or is it all part of the main ECU?
Could really do with some guidance here.
many thanks in advance.
Paddy
Hi I have just had the same problem to the car to main dealer who said two front sensors were not operating correctly, I took off the front bumper (simple job) and found that the wiring had got damp dried it all out and renewed one wire which was badly corroded and everything now work well cost me £1.50 for tape and wire. It will be wort checking
2 minutes ago, Padster72 said:
Ok, so the rear sensors are working after fitting a different module, although still no front sensors. Is the front speaker the same one which give of the fault warning?
check the connections in the unit mine is in the boot take to clips off and put back on again a simple thing but it worked for me
      • 1 reply
      • 5 replies
