Steering column lock fault on dash engine will not start
Hello,
I have removed everything engine , looms, steering column , fuel tank, ecus from a 2001 s type jag 3.0 v6 manual and placed them on the floor in my garage for a kit car project.
As soon as I put the key into the barrel and turn it , it comes up with steering column lock fault on the dash and will not let me start the car. I have removed the lock by drilling out the pins and tried to hole to sensor in to trick the ecu but no luck.
I have basically removed the hole inside of the jag and set it up on my garage floor, any ideas what has set off this code and how can I remove it. I wanted to keep the Jaguar set up nice and standard to keep away from mapping ecus
Any info will be of help along with the clutch change topic I also started.
post-5228-0-10319800-1403735002_thumb.jp
post-5228-0-87376000-1403735021_thumb.jp
post-5228-0-63061900-1403735040_thumb.jp
post-5228-0-20916700-1403735058_thumb.jp
post-5228-0-48131000-1403735074_thumb.jp
  • 6 months later...
