RH Brake light failure
Groomie
You can guarantee 90% of automotive electrical problems are associated with 'EARTHING' although with light failure sensors there is usually an electronic box involved which works with a resistance value. I have had this problem in the past and swapped the sensor with the other side as a test procedure. But then I'm only an Electrical Engineer auto electrical is something different with the Management Software getting involved.
