fitting rear parking sensors
dumdum0910
Welcome to the Club, Adam.
Trevor, who knows all about the X Type, has pointed you in the right direction.
You will enjoy the X type  - great car - and I think you will enjoy this friendly club.
just had a quick look see If I can find this 12 pin plug but no joy.. behind the passenger side rear lense theres 2 plugs but there 2 pin.. any idea were this plug would be ? also I couldn't find the bleeper in the parcel shelf
 HI ADAM
the multi plug should be in the left Corner of the boot
some times it is also behind the  rear panel of the boot same Corner
you will also see the revering module you may have to lift the boot carpet out
the loom plugs into the module one grey plug one yellow plug
TREVOR
PS. I HAVE NOTICED YOU LIVE IN HERTS
IF YOU ARE NOT FAR FROM THE HITCHIN
AREA YOU CAN LOOK MY X/TYPE TO SEE
HOW TO FIT
only 5 miles away my no is 01462 811077 if you don't have the module in the boot the loom should still be there
just a bit harder to find is it the estate or saloon
the loom runs down the passenger side of car there is a plug at the front of the car for fitting front sensor loom and the same at the rear
it may need the module as well as loom
