No air coming out of top vents
GregMiller
2007 S-Type no air coming out of the top centre air vents when these vents are selected vis the mode button, air blows out the foot well vents no matter what mode is selected. Has anyone had a similiar problem.
Sounds like blend motors are either inop or stuck.
With ignition on and fan low switch between up and down and face and listen, you should hear motors changing flaps behind dash.
If they're gone it's not a bad job, just fiddly.
Thanks for the reply Andy.
Switched between different airflow posistions but don't hear no sound of flaps or motors moving. How do I get to these blend motors? Could it perhaps be a fuse that is blown?
  • 7 years later...
On 5/24/2015 at 12:40 PM, Mr Lawrence said:
Think you take the glove box out and there up behind the dash.
Don't know about the fuse but worth a check
Also, have you ever heard a gurgling noise on switch off??
I just came across this post. I have the same issue. I used to hear a gurgling noice for awhile before the front center and side vents stopped working.
I see the stopper motors and the one behind the center console (difficult to get to) seems the only one that’s not moving.
I have a 2008 s-type
There are 5 blend motors, remove them and disassemble. Clean and regrease the carbon tracks. Download the workshop manual for a guide. A gurgling sound on startup is low refrigerant for Aircon. Halfords sell a R134a refill kit but fill in stages, it's easy to go over pressure.
Thank you Justin, the center blend motor has stopped working. Now I have another issue.
When the car is idling, it does not produce cold air but as soon as I start driving (rpm goes up) I get cold air.
The CCM will cut the Aircon if the refrigerant pressure drops too low as well as too high. Call in to Halfords and buy the kit or visit an Aircon specialist.
