Help needed quick! Will 20inch rims fit?
danburydale
Hi All
Got a bit of a dilemma here!! :o
Ordered and paid for 20inch rims (20x8.5) for my 03 X type only to receive a call this morning to say they wont fit! (Even though I have seen them fitted to other x types and the web site I ordered from also said they would! (If not, how come I can order them! :blink:) )
Can anyone offer some advice here please?
1) DO 20inch rims fit with no modification to bodywork?
2) Do I need 8.5 for front and 9.5 for rears? Or 8.5 all round?
3) Tyre sizes? (235/30x20) ?
4) Spacers??
Any advice would be appreciated asap as without it I will now have the performance of trying to get money back or look for a set of 19`s instead :(
Thank you all!!
Hi Darren,
I had an x type and the options for wheels  were 16', 17" and 18".  I also heard that 19" could be fitted also.
However I heard from an expert that the most comfortable ride was from the 16" wheels.
I had 17" wheels and they gave a very comfortable ride.
As the topic is not about performance or efficiency I see point is how they look and 20' looks very good.
Would they fit?
I think so yes. They sell them online for Jaguar X-Type but that may depends on offset and bore.
Mine are standard 245/45R17 all around so to compare to those:
http://www.willtheyfit.com/index.php?width=225&aspect=45&diameter=17&wheelwidth=8.5&offset=38&width2=235&aspect2=30&diameter2=20&wheelwidth2=8.5&offset2=35#content
X-Type default wheels parameters from: http://www.alloywheels.com/jaguar-x-type-alloy-wheels
PCD: 5x108
Wheel offset: 35 to 50mm
Wheel Hub Center Bore: 63.4mm
Wheel fittings: N 1/2inches
Theoreticaly they shoud fit as long as wheels has ET50 to ET35 and correct PCD fitments.
http://www.wheel-size.com/calc/?wheel1=245-45-17X8.5ET38&wheel2=235-30-20X8.5ET35&wheel3=225-45-17X7.5ET40&fcl=50mm&wcl=30mm&scl=50mm
Some theory: http://www.alloyguide.com/pcd.php
Let us know if anybody have 20inch wheels on their X-Type and how it LOOKS ? :)
