Engine runs when key is out of ignition, constant ignition lights
Neild123
Hi all
On a recent trip to wembley my x type developed an odd problem
I turned it off at services and it kept on going!! I had to stall it and remove the battery when leaving it as ignition lights are constant any help would be very much appreciated
Hi Neil,
I have heard of this quite a few years ago in an old car.
I am not an engineer, but `I think the cure was a de-coke.
I would try giving the car a terraclean service which will clean out the fuel system.
Well more bizarre than frightening really guys the car hasn't reached 70000 yet and is garaged for pretty much of its life. I know what you mean by a decoke but think it's electrical to be honest it seems that it is receiving a false signal
Hi Neil, had this problem with s type 2000, got home switched off ,locked up and engine still running, not technical person from memory garage had to replace part at rear of ignition switch which had burned out, hope this makes sense.
