bmnfhg
Compare with SKP900, Key Pro M8, CK100 and X100+
When you wanna to choose an item for key programmer ? which one is the best to choose ?
SKP900, Key Pro M8, CK100 or X100+ ? What’s their difference ? Following us and see together:
SuperOBD SKP-900 Key Programmer:
1) Skp900 is original, can update at superobd official site.
2) SKP900 can work with most cars up to 2013, like 2013 range rover sport is okay, but not all.
3) No need pin code for many cars, can read pin code for many vehicles.
4) SKP900 can do all key lost as well.
5) SKP900 support Toyota G chip key matching.
6) Language available: English and Portuguese.
    The Key Pro M8:
Key Pro M8 can work with old car even before 2006 and both new cars
up to 2012. Key pro M8 is the most powerful and most expensive key
programmer, it’s best for professional locksmith who will make key for
many car models, and it can update online.
    CK-100 Auto Key Programmer – Newest generation SBB:
1) Newest generation SBB, compared with Silca Sbb, CK-100 auto key
programmer newly add some models and even covers up to 2014. CK100 is
available with 3 kinds of version, V99.99, V45.02 and v45.06, V45.09.
2) CK100 V99.99 can support Lexus RX350 07-09, SBB can’t; CK100 V99.99
covers Lexus SC430 02-10, SBB only cover 02-06; CK100 V99.99 can do
Corolla (CAN) from 2009 to 2012, SBB up to 09.
3) CK100 make key by simply plug 16pin cable with OBD diagnostic socket,
no need connect with computer. It can only communicate with the
standard OBDII protocol vehicles. If your car is not standard 16pin
connecter and not standard OBDII protocol, use T300.
4) CK100 has 1024 tokens, after use it up, go to change a chip by following the seller’s instruction.
    Original X-100+ key programmer:
1) X100+ is original, can update online.
2) X100+ is hand-held key programmer, no need connect with any computer.
3) X100+ make key for the vehicle models from China, Asia, Europe and America.
4) X100+ supports Toyota G Chip Via OBD, but it does not support all, some can, some can’t.
5) X-100+ disadvantage: only English available.
Share this post
Link to post
