Washer Pump
ChrisJ
Hi all,
New to the forum so go easy lol
I have recently bought an S Type.. when I bought it I was informed that the Washer Pump for the front windscreen is not working. Apparently, all wiring and fuses have been checked. Pushing the stalk for washer doesnt make a sound from the pump at all. Easy fix ?
Thanks in advance
Bumper off job as far as I can recall Christopher. Changing it over is simple though.
Suggest a replacement from the likes of Fleabay though rather than OEM.
The old pump is simple to test once you get to it. Just pull the wiring connector off and apply 12 volts direct from the battery. No noise = replace pump. If the pump runs then you have a wiring fault.
Thanks Ill get my mate to have a look at it for me and tell him what you told me, thanks.
Whats the recommended amount of mileage before cam chains need renewing ?
