S Type gearbox oil level
Karl.W
Hey all
I have a 2001 (y Reg) s type with the ford 5 speed auto box.
do you check the Oil level in the box the same way as the later boxes by removing the centre plug in the drain bolt and wait for a trickle with the engine running and upto temputure.
The reason i ask is because i undone mine to check the colour of the Oil which was clean but as i undone it it started to gush not trickle and was wondering if it had to much Oil from previous owner.
sorry if this seems a crazy question but was just curious.
Thanks in advance
Karl
Sounds like your diagnosis is correct..Someone has been over enthusiastic in filling and the level is checked on the 5R55N box is as you stated, But there should only be a dribble when the filler plug is removed after warmed up with the box in neutral on a level surface. Confusion arises as given fluid amounts are given are for a dry box and torque converter and once run the torque converter retains fluid even if you drain the box. Options either a bucket under and wait to the fluid to stop or use the drain plug leveler (If it still undoes) to drain some off while the engine is running until gushing stops then go for a run and recheck and top up if needed until just a dribble comes out.
Tip if draining the box to renew the filters. 1st do as for checking the level! If ok drain the fluid and measure it before disposal. This will then give a starting point as to how much is require to refill. The days of the good old dip stick are long gone.
Paul
Thanks so much for your reply, this confirms my suspicions and now making me wonder if this is what is causing my gearbox fault code p0795 solenoid c preasure sensor.
I done a bit of digging and found the following diagrams for the 5r55n gearbox quite useful.
Thanks again for your reply
Karl
  • 7 years later...
i have a 3.0 s type 2001/2 i have lost reverse diagnostics say low pressure on internal valve strip and rebuild necessary left it for a few days reverse came back took it for a run and its gone again how do i check fluid level trying anything to save me from scrapping it
Fluid level is low. Mine had a crack in the Oil filter/pan only about 1.5ltr in it. Warning light would go on every day and usually when selecting reverse. Used a pump and forced 7 litres into the sump - has been great ever since. Don't know about this 'dribble' business that's how to seize the trans pump - an auto is a wet clutch gearbox and needs a large reservoir.
