please help!!
ashg
i have a 02 x type 2.1 v6 sport
i have a very annoying fault, my engine has a complete flat spot around 3000 rpm, it seems like there is no power, i have tried everything.
please help
Electronic Turbo Actuator for Jaguar X Type. it may be this but im not sure with the v6?  but look this up on eBay and read what it says, some sellers give a good discription if your car is doing this,  you can give it a try as youve got nothing to lose, good luck.
11 hours ago, david moore said:
Electronic Turbo Actuator for Jaguar X Type. it may be this but im not sure with the v6?  but look this up on ebay and read what it says, some sellers give a good discription if your car is doing this,  you can give it a try as youve got nothing to lose, good luck.
does the 2.1 v6 have a turbo, I thought it was petrol and only the diesels have turbo's
I may be wrong
yes .... joe your right on that it is just the diesels that have the turbo, so sorry for posts :-(  i think that it could be what you were first diagnosed with regarding coil packs and throttle sensor, best thing to do is connect it up to a Jaguar diagnostic machine which should give you the cause.  again good luck and hope you get this issue fixed...
