Changing Rear Pads
FazerScotty
A quick question - changing rear pads with the EPB.
Park car, place gear selector in "P", remove ignition switch.
EPB activates?
jack up the car.
Remove wheel and gain access to caliper.
My question is - if the EPB is activated and pressure is applied to the brake pads/disc, then how can I remove the old pads and push the pistons back in?
I haven't got any form of manual for the wee beasty (2.5 V6 Auto Saloon)
Hi Richard,
Michaels right, block the front wheels and disengage the EPB before removing the calliper. Your S Type is the same year as mine and I had to put the car into Neutral and leave the key in the ignition to keep the EPB released while I was testing/replacing a speed sensor.
You'll need a wind back tool to rotate the piston back into the calliper - do not try to simply push them back you may damage the calliper. See the attached for your use, I got this from a fellow member and have acquired some other useful goodies in the same way. Let us know if there is anything else you think you need.
Also, please make sure you follow the correct guidance on re-setting the EPB after you have changed the pads.
WSManual.zip
