Low Washer Fluid Warning
AlexWard
Can someone please confirm if the 'Low Washer Fluid' warning is an information centre message or a pre determined light on the cluster please.
I have the sensor wiring in place, connected now to a new level sensor when i fitted the headlamp washers, but nothing appears on the dash nor the message centre when its low.
I would not suspect a wiring fault at present as it looks (suprisingly) factory fresh under the front drivers wing.
All help appreciated.
Alex
