Climate control problem.
Raistlin
When I set temperature to "Lo", I get nice cold air from the passenger's vent but barely cool from the Driver's side.
Air con was serviced rencetly and is perfect.
I worked out that the driver's side temperature blend flap might be stuck in one position but observing the servo motor when changing temperature settings over the full range shows it to be moving end to end as it should do.
Anything else I should be considering please?
Hi paul
its usually the dccv starting to fail and passing hot water
drivers and passenger side are seperate valves
are they both cold, when the engine is cold, if so, must be dccv passing
very common s-type fault
  • 5 months later...
