Xf washer pump
Patch58
Yep
Just changed mine yesterday
£11 from ebay  for the pump ,Old one had the filter in the suction and it was not clogged ,New one has the rubber seal but no filter.
I parked  the jag away from kerb turned to fully right .removed 2 plastic clips holding the wheel arch line and just pulled out the old pump and swapped it over .AND it worked better than before .
I also checked the non return valve under the brake fluid reservior cap and it was OK
Good luck
