XJ12 H.E. engine in a XJ 12 Serie II 1974?
Antoine Bussat
Hello, does somebody know if it's possible to fit a V12 5.3 H.E. (Serie III) in a XJ12 1974 Serie II (fitted with 4 stromberg engine) body?  If yes, are the fixing points (engine to chassis) the same for both engines? Are the Borg-Warner 3speed GM3 the same ones for both engines? Thank you very much for your help.
