Air conditioning not cooling.
Seabazz
Hi fellow members, I have a XF 2012, 3.o diesel. I've had the air con regassed and there was no leaks. But it doesn't blow cold, I've been told the compressor isn't engaging.  And needs diagnosis work to find the reason. Is there any work I can do to diagnose the fault, where would I start. ? Any suggestions or solutions will be gratefully received.
Regards Seabazz.
Regards Seabazz.
Use a good diagnostic tool and see what codes you can find which may be relevant to your problems.
Best Wishes and Regards, John
