Gearbox oil and filter change help
Mark s-Type
Hi, just done some work on my 2002 2.5 and saw a leak from the seal on the gearbox. This is one of the jobs I have not yet done. The auto box works fine, but I will need to do this job soon! I would like to know the best place to get a Service kit from (pan, Oil, filter etc).  Any pointers would be gratefully received.
I have seen kits on eBay, but am not sure about the Oil they use. Thank you.
2 hours ago, Mark s-Type said:
Hi, just done some work on my 2002 2.5 and saw a leak from the seal on the gearbox. This is one of the jobs I have not yet done. The auto box works fine, but I will need to do this job soon! I would like to know the best place to get a Service kit from (pan, oil, filter etc).  Any pointers would be gratefully received.
I have seen kits on eBay, but am not sure about the oil they use. Thank you.
My advice would be to make certain you buy Genuine Parts.
Best Wishes and Regards, John
Hi all, just an update. Spoke to Mill autoquip today, and they put a service pack together and as they know I am a carer they did it at trade price so £140.59 cheaper than eBay. Booked in on the 15th Nov for this work and MOT. Thanks for your help!
Hi all, just wanted to get the job done this time. I say that as I have seen there is an alloy gearbox pan cover. This costs about £125.00 and the filter kit is £56 when you do an Oil change. Are they any good? Do they fit? Has anyone used one? What would your opinion be?
Hi all, just wanted to get the job done this time. I say that as I have seen there is an alloy gearbox pan cover. This costs about £125.00 and the filter kit is £56 when you do an oil change. Are they any good? Do they fit? Has anyone used one? What would your opinion be?
Despite what Jaguar might advise, I had mine done at 60,000 miles (about 7,000 miles ago). I would recommend that you use genuine Jaguar Parts.
the metal one is landrovers with the same gearbox
unless your thinking of doing some serious off roading , then I would'nt bother
the plastic one work quite well and if you use genuine zf part never leaks, only after market ones do.
also the filter in the plastic one looks larger, the metal one is a smaller serperate filter
