V8s/c not starting
Bryan Ceil
On 11/2/2022 at 9:08 AM, Bryan Ceil said:
Started as usual first time then stopped never started since.pumps priming had a plug out looks (gray to pink)no oil
Check (or simply replace "on spec") the Crank Position Sensor. These can fail suddenly resulting in a sudden FTP with no fault codes shown. About £15-25 on eBay for a pattern one, around £100 from Jaguar but as Fords use the same sensor, shopping around can find you a bargain!
