X-Type front passenger door ONLY opens when the weather is ICE cold.
KirkieP
I have a 2008 X-Type with a strange problem.The front passenger door will open manually from the inside but will not open from the outside.It doesn't usually open using the remote either however the strange thing is it WILL consistently open and close (manually or using the remote) in ICE COLD weather.All other doors open and close as normal.Can anyone tell me what's going on here and how to fix this ?
On 1/21/2023 at 11:56 AM, Jimbov8 said:
Welcome to the forum.
Unfortunately, the only way to know what’s going on is to remove the door card and check the movement of the linkages.
Enjoy.😊
Thank you Jimbov8.
