Hello
Can anyone tell me where to get the led's for my xk 2010 rear light. If you know the type,size or voltage i would be really grateful.
I was wondering if other models of a similar year have the same ones,I could use as a possible donor. Thank you for your time.
Hi Andy, not sure what you are after here as the LED elements for the rear lights are not available as individual lamps, but as a feature part of the rear lamp cluster.
Go to the Jaguar Classic Parts website and you will be able to see which part numbers you ned to be looking for. Note that JLR Classic are not yet back to selling online spares following the cyber attack. The link below should take you to the correct page, but as you will see, the parts are VIN specific.
Rear Lights | Jaguar Land Rover Classic Parts
13 hours ago, Andy64 said:
Hello
If you can’t source them from electronic stores then these guys will be able to do it for you.  https://www.ebay.co.uk/itm/256406369024
I have read of people repairing the lights themselves so it is more than possible.
Hello Jimbov8
Thank you for your very useful information. It is the main rear tail light that has stopped working. I’ve found out that soldered to a thin plate are led lights in series. If just one goes then they all stop working. I know the led light on the boot is different but I haven’t had to look for replacement yet. There is a video on YouTube showing a chap changing just one blown led to fix his light I’m hoping I can do the same. Take care
N6 jmx
Thank you for your help, the main rear light is my problem, I’m sorry I didn’t make that clear. I forgot the light on the boot that joins with rear light when shut. I have seen inside a rear light on YouTube and they are individual led’s soldered to a different thin circuit plate. They can be removed individually. If I can’t get details of the correct led I will have to open the light I think. Once again thank you for taking the time to help. Andy
