Battery Not Charging
Started my XF after 6 days in my garage, we have temperatures as low as minus 13c, sluggish but started then i noticed the Red Warning on heads up display. I continued with my short journey returned to my garage. I looked under the bonnet to see belt was running, alternator connections secure. Switched off the ignition restarted again no warning signal. Has anyone experienced this. Any comments appreciated.
This has all the hallmarks of low battery voltage. A full recharge should see you right.
Thanks Jim. Probably my fault I usually charge the battery every week during the winter months but missed a few. Like you said i put it on charge immediately and we ar back to normal. Thanks again.
