Electric mirror adjust not working
harpersimon
Hi All
Wondering why my mirror adjust doesn't work
So far checked fuses 22/30 which are the only ones listed with anything mirror related in the manual  - although I can't see anything obvious like "mirror adjust" next to a fuse..
So - being as neither side work, would anyone know a possible reason? maybe the switch not connected properly ? how do I get it out? door card off?
etc..
thanks
  • 5 years later...
If you take off the mirror casing ,it only clips on, you will be met with a lump of white corrosion.   Tie a towel or something on to  the mirror to protect your paintwork then liberally spray Plus gas , leave to soak ,when eventually the mirror starts to move freely , apply chain grease.
Both of mine are due this treatment again ,lasted two years before getting sticky.
Mike
  • 4 weeks later...
The complet job can be seen here:
