Windscreen wipers won't stop..
Hi all has anybody had a problem with the windscreen wipers not stopping here's what I've tried so far
Cleaned up the fuse
When fuse is removed they stop
Disconnected wire at the switch and they don't start but if you disconnect the wire at the switch while they are on they don't Stop?
When they are on if you follow them with your hand and try to stop them in the position they should stop in and hold them briefly they stop....
Could the motor be overrunning ?
Any Ideas would greatly be appreciated as I'm no electrician
Cheers in advance
Kenny.
