    Membership is completely free, and our community is built by enthusiasts, for enthusiasts. We鈥檙e a proudly independent, non-official club, so all the help and opinions you鈥檒l find here come directly from members with real experience of Jaguar Ownership.
Hi all,
It's been a while since I posted here but I've got an issue I hope someone can help with.
In the past few聽weeks I have purchased a 2005 X-Type Sovereign to replace my 2001 SE that had an unfortunate MoT disaster that was no longer cost-effective to repair 馃槥
The Sovereign is great, but it was lacking one feature - Bluetooth.
I have purchased the later BT module and the antenna, as well as a Fibre cable and linked that in to the Fibre loop. Found the wiring loom for the Bluetooth module tucked away and basically fitted everything and, amazingly, it worked first time! All is good and I can use the screen to dial, phone contacts sync and people can hear me fine. Result!
Well, not quite. The Sovereign has Voice control and I can't get it to recognise any Voice commands for phone at all apart from the one to display the Phone screen. All other Voice commands are fine (Radio / Climate / CD Changer).
I have been into the secret menu from the screen using the Phone and Menu buttons and code 1971 and checked that the Phone module is listed as installed and this is indeed there and present.
What do I need to do to get the Voice control module to recognise the Voice dialling commands as well as the others that are already working fine?
Thanks in advance for any pointers.
TMW
Hi Tim, have you "trained"聽 the voice control system to recognise your voice? There is a procedure to go through with different commands. You will need the book from your pack
Yes, voice is known and I can control the radio / cd / screen / climate with voice and no issues at all.聽
It's just the phone controls from voice that are not recognised.聽
TMW聽
