Hi All,
I have got "DPF Full - See the Owner's Manual" warning message on multiple occasions in the dashboard. I am aware of the temporary solution of revving in manually to 3,000 RPM for 1 hour. Any suggestions on a permanent fix would be much appreciated.
Best Regards,
Jerome
You could have it professionally cleaned     or replace  the d,p,f.  running it at 3000  could well burn off some of the soot   but. you may need to do it  a few times to get a full regen ..
