multiple warning lights / f pace 2017 2lt diesel
Hello,
Multiple errors suddenly appeared on my 2017 Jaguar FPACE and they persist:
Restricted performance
ASPC not available
Stability control not available
AEB not available
Forward alert not available
What could I do and what is the solution? What Could it be related to ?
Hi Kadir, do you know the age of the battery in your car? If it were still the original, then a suggestion to fit a new battery - and tell the car via the OBD port that a new battery has been installed - would be number 1 on my list.
Modern cars, especially Jaguars, are extremely sensitive to battery voltage spikes and the battery's ability to start the car is no longer the prime indicator that the battery is still fit for purpose. After the battery reaches 5 years old, it needs to be considered for replacement - even if your local garage does a test and says it's fine!
Receiving multiple, apparently random, error messages is a first sign that all is not well with the vehicle's battery. There are others - such as Stop / Start being inoperative for lengthy periods.
Consider changing the battery for a correct rated replacement if you are unsure of the battery's age.
