Air Con
Air con not worked for a few months just been to have a Re gas but told it must have a leak as it won’t Re gas but no physical signs of a leak is there a common place for leaks on the XE any suggestions would be great
xe r sport 2016 28800mls
If you are not able to hold gas then you have a pretty major leak. System needs pumping full of dye gas to identify where the system is leaking from mate
