Hello, I have a Jaguar FType 2015 which has a electrical issue. The airbag light (yellow) will show and not go off and then the tyre pressure warning light comes on. All the tyres have enough air in and the system is reading the air pressure correctly. When I do a re set they go off for a few days. The battery is new and I have made sure they car is going in to sleep mode. Not sure what to do next and has anyone had the same issues? Thanks Ash.
Have you "told" the car it has a new battery? The car's brain needs to be informed that there is a new battery fitted so it adjusts the charging rates from the alternator. Use either a decent code reader, or a friendly local garage with the appropriate diagnostic equipment.
Alternatively, may be something more insidious in the ECU or wiring.
N6 JMX
