  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Hi All, New Member, Newbie Questions
Hi All
Newbie here, so be gentle ;o)
Had (in order) XF, XJ, XKR-S, XFR (stolen), 650i (sorry for defection!), XKR-S (again, since last Thurs, 55th b'day present to me!)...
So, is there any point actually updating the stanav maps via DVD, for a 2011 car? I can see 2020 map disks online around ÂŁ20, is it actually worth it for a car of this age?
Jason
Hi Jason, welcome back to Modern XK motoring. The DVD based Satnav system in the XK is now well out of date and whilst you may be able to find "pirate" discs on the web, claiming to offer "updated maps", these can create more problems than they solve. I know of several instances where the installation of these update discs have actually caused the whole infotainment system and the Touchscreen to freeze and become corrupted and unusable. I am sure others will be along soon to advise that they have had a very positive experience, but until you slot the disc into the DVD player in the boot, you don't know what result you will receive.
In my opinion, there are two ways to sort the out of date map situation. A) get yourself a good phone holder and use the Maps App from your phone. B) search around and you will find a number of companies who can install Apple CarPlay or Android Auto into your XKR-S depending on your phone preferences. These modifications give you a truly modern update for use in the car. Please note that the installation to a 5.0 litre XK is not straightforward and does require a specialist, it is not a DIY task unless you are an experienced Electronics Engineer.
Incidentally, your profile information says your car is an XFR-S, not XKR-S.
Good luck.
N6 JMX
Hi N6
Many thanks for the v informative reply mate, much appreciated 🙂
In terms of the of the Android Auto option, do you know a rough price that they charge, as I may well be interested in that... Already got full paint restoration and ceramic coating booked in for later in Feb, and leather restoration in next few days, so may well put this on the list!
Jason
PS, will update my profile, was late when I set it up!
Hi Jason, one of the companies I am aware of is Cartronics - see link below. I have not used them as they are a bit far from me - but I know others in the XKCC have got their Android Auto system installed to a late model XKR.
https://www.cartronics.co.uk/
I think the installation cost is somewhere around ÂŁ1,400, pricey but a long term modern solution. If I were closer to them I would certainly give it a go.
There is also a version from Mr12Volt, but I only know of that being installed to a 2009 model - the 4.2 engined models have a slightly easier installation procedure without the fibre optic involvement.
Good luck with your choices - might like to consider joining the XKCC, only ÂŁ10 per year and a car club specifically for XK enthusiasts. They have an event being planned to attend a gathering at Oulton Park in Cheshire in August, celebrating the 30th Anniversary of the X-100 and 20th Anniversary of the X-150 models. Jointly organised by JDHT and MSV, they are looking to get up to 1,000 XK on the track for a parade. See the XKCC at this link below:
XKCC | Modern XK Club
N6 JMX
Hi N6
Been away for a few days...
The Cartronics one looks like a head unit retrofit, will research if this removes any functionality, whereas think the Mr12Volt one utilises the current screen, need to do some research 🙂
Have signed up to XKCC, hope to make meet later in year, maybe we'll get to say hello!
Cheers again
Jason
