rear sway bar
hi guys i got a 2002 2.5 awd this may have been asked be for im putting on new bushes and drop links on the back but the drop links i got are not the same as the ones i took of ats the old ones are like ball joint type that pop onto the bar and the new ones are bolt on to the bar i have looked for the pop on ones but cant find them  can slome  one help with this thanks
right guys the ANSWER to my own QUESTION is that the drop link had can off at the top ball joint that go,s on to the sway bar  so  it leve,s a ball at the end of the bar so the new one bolts into the bar in snstead of it bolting on to it so simple a answer if  you have dune it be for but i havent this is for the newbie like my on there first jag x type
