lights stuck on full beam
hi all
I have just bought an xtype 2002 but have a big problem.  Each time the main headlights are on they go to full beam.  When on side lights they flash perfect but as soon as on main lights they goto full beam.
I have changed the relays, assuming the ones i have used work, but nothing.  I have now removed the stalk and the full beam light does not come on the dashboard, could it be the stalk???  If so how come it flashes ok??
Any help much appreciated
Thanks in advanced
Hi cyberj
I had a similar fault, it turned out to be a cambus fault so had to swap gem unit and clocks.
I would start by reading the fault codes that should "shed light on the problem" sorry couldn't be more helpful
Good luck
Thanks Mike, I will get some time this week to play with it and will update the thread accordingly, thanks again
Just a quick update, turned out to be the full beam / indicator stalk.  £15 off ebay and job done, thanks
