Problem replacing knock sensor
I have a 2002 Sport X-Type 2.5 with a bad knock sensor.  I'm having a problem getting at the bolt holding the knock sensor.  It is very close to the coolant inlet tube and cannot be reached with a standard socket or wrench.  I would appreciate any suggestions or advice from someone who has previously replaced the knock sensor.  Thank you
