Water draining incorrectly through rear door.
Anyone else suffered from water draining through the car door and coming out on the inside, basically between the door card and door metalwork it snaps into?  Noticed mine was doing this when I washed it today and opened the passenger door.  Was a small trickle of water down onto the carpet as basically the water was draining onto the top of the inner seal rather than outside it.
Used to have a Toledo V5 that did something similar.  I seem to remember I had to get all the membranes in the doors replaced to prevent the normal water draining through from draining down the wrong side.
Bit of a ball ache as I really do not want to go through the nightmare of wet carpets as getting them stripped out so they can dry properly is a pain.
