Hi all. I recently became the proud owner of a 2008 XKR (I introduced myself earlier this week) and am keen to sort out a few minor niggles, the first of which is an inoperative heated rear window,
I was hoping it might just be the fuse, but this seems fine so my next thought is a failed relay. Does anyone know where this is located as I'd like to change it before I go see the garage.
Many thanks in advance.
Rich
  • 2 years later...
Quick update - this turned out to be a broken connector that Jaguar wanted £800 to replace the rear window, but I was able to solder in 10 mins at zero cost!
  • 4 weeks later...
Well done, do you actually notice it do anything now it's fixed? The window on my x150 xkr takes forever to clear!
It takes a while but does eventually clear the screen, and even if it’s only partially clear It’s better than nothing 😀
