Xj627 diesel 2009 rear wishbone fitted
I've had a rear wishbone fitted by jaguar  given clean bill of health. Just noticed back axle is out of line since it has been fitted.  Can I have it adjusted or do I need other side replaced
Hi James,
That's annoying for you. Personally I would take it back to them and point out the problem.
If it happened after they fitted the part they should put it right.
Hope you get it sorted.
Kind Regards,
Julie.
Thanks  Julie will give them a ring
James
