Engine management light.
Had a 2005 x type 3 yes now only 33060 miles on it, but the engine management light has come on.
Any suggestions on what it could be? I ran a diagnostic check in the hidden menu bit no codes came up.
Hi Chris,
Are there any loose wires?
Check all wires going to ecu.
a little Is your battery old or run down? If not driving much may be a little low.
Kind Regards,
Julie.
You will need to plug it in to a code reader, without codes it could be anything
Hi sorry thought you had read the codes.
a good cheap scanner i believe is 19.99 from Eurocar parts
reads codes - street wise.
