Crank sensor
Is there any way to reset crank sensor on  2015
Xe
2.0d
Crank sensors either work or they don't, no half measures. I'm guessing it's a non-starter? If so, replacement is the only real option.
https://www.ebay.co.uk/itm/125200276397
I believe that's the correct one for your car but double check as you haven't provided many details about your car.
Starts and runs fine. Just throws a code up and engine management light comes on. Clear it with obd but comes on again later on
Check your wiring to the CPS, might also be worth unplugging and spraying contact cleaner into the plug and the sensor contacts, refitting/unplugging a few times then a final squirt on both with contact cleaner before final connection and then reset again on the OBD, see if that improves matters. If not, renew the sensor.
I know when the CPS went on mine it was a non-starter and no fault code thrown either! 😮
