2011 XK A pillar trim removal
I am in the process of removing the A pillar inside trim on my 2011 XK, left hand drive model. After researching the process to remove the trim it seems that it should simply pop or pry off if necessary. The bottom of the trim seems to be loose but the top absolutely will not release. My car also has the microphone mounted near the top of the trim panel. Is the microphone attached such that it is keeping the trim from releasing? The microphone has two rivets attaching the back to something behind the trim. It looks like I may need to drill out the rivets to release the microphone and the trim. I wonder if anyone has experienced the same problem. Thanks in advance!
