Fuel door the flat black cover only fell off, cannot attach
The black flat fuel door cover fell off, it does not fit back on the strap of the hinge, not sure it it had another part glued on to fit. Help the door still opens .2027 f-pace
help pls
Hi Jana
It should simply slide back on. Open the fuel doorand then the cover should slide on.
This is from an XF but I think the mechanism is the same.
Good luck
13 hours ago, Big John said:
Hi Jana
Good luck
Thanks John I will try sliding it, I was trying to click it on somehow.
Thanks so much, I did it👍👍👍👍
It sounds like the hinge or clip that holds the cover might have broken. You might need a replacement part for the hinge or the cover itself. A dealer or parts shop should be able to help with that
