My dads jag had died. Opened car (keyless) now both battery's have died can I get into the boot with key
Hi Karen, if you have gotten into the car, then pop the bonnet and fit a secondary battery or booster pack to the +ve and -ve terminal posts under there. Don't do anything else other than then use the boot switch to open it.
If need be, you can also use these posts to charge the main battery, but it sounds as though that has gone past the point of no return and needs to be replaced.
