Hi,
I have owned my jag for some 15 years. A couple of years ago I had a reduced performance warning which put the car into limp mode. I took it to my local jag dealership who informed me the super charger cooling pump was failing. I coughed up well over a grand for them to fix it. Which they did. But since then my aircon leaks. The dealership had closed down ( maybe lost their franchise?). I have taken my car to a couple of so called aircon specialist but they just can't fix it, apart from relieving me of money.
My question is, if the super charger cooling pump being replaced could have caused the aircon problem? I'm now at my tether. Can anyone help or recommend someone who can?
Kind regards
Dar
Hi there. They must have undo/redi something incorrectly?
So called aircon specialists...I would find jag indy, they should sort it out as they know jags through and through
Hi Bik3Rz,
You mention jag indy. Do you know where they are based? And is it near Bristol?
Cheers.
Thanks mate,
I will contact them, as it happens one of my friends just mentioned Swallows to me. He told me they are excellent. I'll give them a call and get it booked in.
Many thanks for your help, if there's anything I can do for you just ask.
Dar
  • Like 2
    • Jaguar Icons
      • 11 replies
