Hi all.
Need help finding these parts for my motor. The 2 short hoses ( if you can call them that) have at some point been cut through. I only noticed recently and on start up there is a very loud noise of air intake. This is accompanied by popping and some lumpiness, which eventually settles down. Im wondering if the excessive air influx is affecting the fuel delivery/mix and causing the lumpiness. In any event these parts need replacing. Many thanks
I think your best bet will be a scrapyard as the new ones (for the petrol engine) are NLA :
https://parts.jaguarlandroverclassic.com/parts/index/part/id/400.1284.3696.16346/brand/jaguar/
As a "prove it or not" test, you could wrap duct tape around where they have been cut, if the problem disappears you have a semi permanent repair (as long as you use duct tape on those two ducts) that will keep you going until you find a used item in a scrappies.
