Hello from a new member 😀
My boot is locked on my 2002 xk8
When I press the boot button in the car, it says valet locked, I  I turn on the car using the black key, still locked, I put the key in the secret key hole between the xk8, it will not unlock, then tried the button on the boot, still locked, the fob does not work, I have changed the fob battery and reprogrammed both keys, the boot is still LOCKED,  PLEASE ANYONE HAVE ANY IDEAS
REGARDS
EDDIE MORTLOCK
Hi Eddie, if I remember correctly, the XK8 has a "Valet" button on the fob which must have been activated - pressed inadvertently. To reset out of Valet mode, you need to unlock the car - driver's door, from fully locked, using the black headed key - not any of the fobs. For some reason, this information is not contained in the Owners manual.
N6 JMX
REGARDS
EDDIE MORTLOCK
Hi Eddie, watch this video from 4 mins in, it may help you get in.
Hi Jimbov8
Very useful I will try that one through the grommet, when the rain stops
If the red button as been pressed down, there no way to it when the boot is locked, because of the fittings around it
Thanks Eddie
4 hours ago, N6 JMX said:
Hi Eddie, if I remember correctly, the XK8 has a "Valet" button on the fob which must have been activated - pressed inadvertently. To reset out of Valet mode, you need to unlock the car - driver's door, from fully locked, using the black headed key - not any of the fobs. For some reason, this information is not contained in the Owners Manual.
N6 JMX
Hi N6jmx
I have tried the black key to start the car, failed 😕 the boot is still locked
Thanks Eddie
