Hello from a new member 😀
My boot is locked on my 2002 xk8
When I press the boot button in the car, it says valet locked, I  I turn on the car using the black key, still locked, I put the key in the secret key hole between the xk8, it will not unlock, then tried the button on the boot, still locked, the fob does not work, I have changed the fob battery and reprogrammed both keys, the boot is still LOCKED,  PLEASE ANYONE HAVE ANY IDEAS
REGARDS
EDDIE MORTLOCK
Hi Eddie, if I remember correctly, the XK8 has a "Valet" button on the fob which must have been activated - pressed inadvertently. To reset out of Valet mode, you need to unlock the car - driver's door, from fully locked, using the black headed key - not any of the fobs. For some reason, this information is not contained in the Owners manual.
N6 JMX
REGARDS
EDDIE MORTLOCK
Hi Eddie, watch this video from 4 mins in, it may help you get in.
Hi Jimbov8
Very useful I will try that one through the grommet, when the rain stops
If the red button as been pressed down, there no way to it when the boot is locked, because of the fittings around it
Thanks Eddie
4 hours ago, N6 JMX said:
Hi Eddie, if I remember correctly, the XK8 has a "Valet" button on the fob which must have been activated - pressed inadvertently. To reset out of Valet mode, you need to unlock the car - driver's door, from fully locked, using the black headed key - not any of the fobs. For some reason, this information is not contained in the Owners Manual.
N6 JMX
Hi N6jmx
I have tried the black key to start the car, failed 😕 the boot is still locked
Thanks Eddie
Hi Eddie, the information said to unlock the driver's door with the black key - nothing about starting the car with the black key.
N6 JMX
22 hours ago, plonker said:
Hi Jimbov8
Thanks Eddie
Keep us updated as to how you get on.🤙
N6 JMX
Ok 👍
I do unlock the car using the black key, and that setts the alarm off
My fob does not work, I have changed the battery and reprogramed and still it will not come out of Valet mode, believe me I have tried everything to try to get out of Valet mode and unlock the boot
All have FAILED
DESPERATE
Regards Eddie
16 hours ago, plonker said:
Ok 👍
All have FAILED
DESPERATE
Regards Eddie
Some more info on the keys;
The one on the left is the Valet key; on the right is one of the Black 'all function' keys. Not a lot of difference in the photo icon_cool.gif
On the Valet key, the Green head is near enough the same shade as the surround of the Jaguar emblem in the centre. The Black key should be a contrast.
If you look at the tip of the Valet key, it's different from the Black keys. The Black keys have a 'collar' cut round the tip which the Valet key doesn't. This shows up in the photo
Thank you for your interest Jimbov8
Believe me, I am using the black key only, it will not clear the Valet mode or open the the boot between the hole xk8, I am coming to the conclusion that the fob is not talking to the car, even though I have changed the battery twice and reprogramed both fobs twice
The red button in the boot, if someone as pressed it down, I don't know any way into the boot
I don't know why the red button is there
Thanks Eddie
If you are referring to the button in the middle of the boot plinth then that is another boot release switch. It is a push button switch. If it looks as though it is stuck in then try to release it with a watchmaker’s screwdriver.
With reference to the key lock, how far can you turn the key when inserted. If you’re not able to turn far enough then it won’t unlock. Try WD40 and then working the lock, it may be gunged up through lack of use.
