jaguar x150 infirmatjion screen flickering but only jag logo showing  battery replaced with 100amph modules replaced and tested all working not sure if there's a wire break or a hard reset can anyone help
Hi Colin, you indicate your problem is with the X-150 model, but your profile descripting infers you have the X-100 model from 2001, need to clarify which model you have the issue with.
Before you changed the battery, did you have any need to jump start the car? If yes, then you may have fried the video screen that is the display in the X-150 model.
