Hi all, I have a xjl  2014 the drivers side and passenger side windows skuek when going up and down . Tried wd40 dry .
Iane
Put all the windows down and then spray silicone lube spray into the top of the window channels for a few seconds, preferably using one of those long spouts. Only spray onto the vertical/near vertical parts of the window channels.
Once all sprayed, start the car (to avoid flattening the battery) and exrecise all windows up and down several times.
Not sure if you have Toolstation in Eire but this is the sort of stuff :
https://www.toolstation.com/action-can-sp-90-silicone-lubricant/p34151
It's also good for spraying on door seals, leave to soak and then gently wipe off the excess to help prevent the door seal freezing to the doors in cold weather.
