Drivers door lock actuator
I have a problem with my central locking, when using the remote it locks then immediately unlocks! Or vice versa if it is locked! I have been locking and unlocking with the key. I have traced the fault to the drivers door lock actuator and purchased a good used one.
Today I decided to fit it, so do door panel off, electrical connection off and plugged in the replacement to test it, everything now works as it should! Now the fun part fitting it!!! I can remove all the  torx head bolts but cannot get past the metal plate to disconnect the rods from the actuator! After 2 frustrating hours and much swearing I have put it back together for another day! Any tips anyone? otherwise I fear it may get put off for ever!!!
  • 2 years later...
Hi, did you ever get a solution to this problem?  I have the same job to do myself, only on the front passenger door.  If there are tips or tricks I would appreciate knowing before I attempt the job.
