p0251 code
Quick question , driving home today and I booted it in fourth to clear out diesal pick up and the car lost power , the glow plug light came on . Took it to my garage the code is p0251 which they cleared and now it drives ok , Any ideas
regards paul
Welcome to the club, Paul.
PO251 is Injection pump metering control according to my list of codes-  2.0 and 2.2 litre duratec engines.  It could have been not enough fuel getting through when you gave it a bit of welly.
What mileage has your car done?  I ask that question as glow plugs are expensive things to buy and they need careful looking after.
A month ago I had my 2.7 diesel Terracleaned and it has made the world of a difference.  It has made the car a little more responsive and given me a better MPG.
Other diesel owners have had the same experience with this service.  It might be good for your car at a cost of less than £100.
Hi Peter,
She has 93000 on the clock, i must admit i realised that i ran the fuel gauge down quite low to about 19 miles left so maybe it picked up some rubbish and when i booted it , this stopped the fuel getting through , throwing up the glow plug light and going into safe mode, the terraclean i have heard good things and bad , so not sure what to do with that, i am just wondering if she will be ok to take on a long journey this weekend as that has put doubts in my mind . its the 2.2 d sport premium model
regards paul
Hi Paul,
Terraclean is very beneficial for diesel engines, and I only had mine done after much research. And with 93k on the clock the service will come in much cheaper than a new fuel injector  or glow plugs.
I also use Shell Vitro and find it much better than supermarket fuel.
P,S. A long run will do your engine a bit of good.
 Hi Peter,
i have driven it to work today and she was fine, only eight miles there and eight miles back, my concern with going for a long journey would be if it is likely to happen again.
regards paul
When was your fuel filter last changed, and is it a quality one (Bosch, Delphi)?
since i have had it , its never been changed, had it a year and only done 4000 miles
So it may have been on there for years? I would fit a new one as a matter of course anyway and it may solve your problem.
ok , cheers .
